29-11-2014 #11
To me the goal is to use the machine and it be accurate. If I have to start programming Adhoc micro processors to do what is in affect a simple operation then i'm not interested and neither should I have to be.! . . . . . If your prepared go to the bother of programing hardware then why bother buying any controller or drives and just build your own.??? . . . Why not because it aint worth the trouble trying to re-invent the wheel.
Most people with steppers don't buy the IP-S because it can do slaved motors or calculate switch error (they are daft if they do or have too much money.!) They buy it because it's quality unit which is very powerful, versatile which offers industry standard I/O with an easy upgrade path to using high count servo's and getting the full potential from them at a later date if required.
Yes other controllers like the ESS can do this but they don't have the quality or smoothness like the Cslabs products and not until you have experienced both or several manufactures controllers do you know this.! . . . . I've yet to use anything in the same price bracket that comes near the Cslabs stuff.!! . . . If I had I'd be shouting about it.!!
ES-D1008 + CSMIO/IP-S wiring
By Matt81 in forum CS-Lab (CSMIO)Replies: 3Last Post: 03-05-2014, 10:56 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
