Thread: Leadshine EasyServo Question
You can get to the encoder DRO's in Mach3, do a search in this document for them; http://www.machsupport.com/forum/ind...0;attach=27839
Then you might be able to write a Mach3 'Brain' to achieve what you want.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
01-12-2014 #2
Thanks, Eddy, at the time I went the add-on route (Wizard) but I could not figure out a way to read the oemDRO's while the machine was moving e.g. if you do a
code "G1 X 100" the script would just sit on that line till the movement is completed before moving to the code that gets height from the sensor so I had to go the move stop, then get height route.
I'm not familiar with brains and will certainly read up on that. Would a brain allow some custom script to execute while some g-code is executing, as that would be exactly what I need? For interest sake the sensor I have is a Wenglor CP35MHT80
01-12-2014 #3
But only if the encoder talks to Mach3 and in this case they don't. The loop is closed at the drive and Mach never see's the encoder so that won't work.
Not sure if the drives will report encoder position thru the serial connection but suspect they will or could be made too.? In which case it may be possible to feed this to Mach3 then use a brain like Eddy suggests.?
01-12-2014 #4
Jazz if its possible to get the driver encoder position back into Mach3 or even use the build in soft DRO's in mach3 like eddy suggested along with the sensor output it would create some very useful possibilities to toy with like e.g. a contactless edgefinder for setting work-offsets. I might be totally wrong but my gut feel is that the mach3 soft DRO's does not always know where the machine actually is in real-time while moving if you use a controller that does buffering etc ?
01-12-2014 #5
If it does all come together this is a good video on Brains; https://www.youtube.com/watch?v=O8V7dZy02og
01-12-2014 #6
Thanks Eddy, that helps.
02-12-2014 #7
I've just read the servo manual and it looks like the only way to get at the encoder is via that RS232 interface.
21-12-2014 #8
@mitchejc
Don't know if this is any use for your limits application, Hiwin - Intelligent Linear Guideway ( Page 4 ); http://www.hiwin.com/pdf/lg/linear_guideways_e2.pdfLast edited by EddyCurrent; 21-12-2014 at 09:20 PM.
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
Wiring up the Alarm output on Leadshine AM882
By Shinobiwan in forum Motor Drivers & ControllersReplies: 42Last Post: 01-08-2017, 02:07 AM -
Controller for 8NM closed loop leadshine drivers
By Matt81 in forum Motor Drivers & ControllersReplies: 5Last Post: 19-06-2014, 09:08 AM -
FOR SALE: Leadshine HBS86 kit - 8.0Nm motor + driver
By dsc in forum Items For SaleReplies: 0Last Post: 07-04-2014, 04:46 PM -
Leadshine Digital drives bulk purchase
By D.C. in forum Marketplace DiscussionReplies: 32Last Post: 11-11-2012, 08:57 PM
