I suggested 16500 to 18000 rpm earlier because that seems to be a sweet spot on my machine, (16500 especially) it gives a good finish on the smallest cutters in hardwood and less tool wear (cuts per second).
15-12-2014 #2
balancing cuter speed, DOC and feed is the key I think, but generally low cutter speeds (peripheral /curcumferencial speed- varies with diameter) is an important consideration... when I get consulted on poor performance/finish on router & spindle moulder work it is nearly always running too slow, usually because the operator is inexperienced or scared of the tool.... should not be a problem with CNC though I don't think
19-12-2014 #3
Thanks guys, the missing steps issue turned out to be the pinions slipping, ill try running it at 24,000 rpm and higher feed rate and see if that improves the cut quality.
So, what am I missing?
By Davek0974 in forum 3D Printing MachinesReplies: 4Last Post: 25-02-2014, 12:52 PM -
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Strange problem, possibly missing steps?
By Philly in forum Chinese MachinesReplies: 5Last Post: 26-10-2012, 06:36 PM -
Boxford TCL 125 missing software
By Boxster in forum Boxford LathesReplies: 13Last Post: 03-07-2012, 06:21 PM -
Missing Steps + Stalling X-axis
By danielbriggs in forum Linear & Rotary MotionReplies: 5Last Post: 02-09-2010, 02:59 PM
