Thread: Help with drill-Mill conversion
Get a cheap thermoprobe from Maplin (£19, here) and check motor case temp. Anything above 85degC and you need to be thinking cooling/heatsinks on the motors.
30-10-2009 #2
Thanks Irving, Already got that on my meter, and one of those infrared jobbies.....Just forgot to use them.:whistling:
So is it ok for the motors to get hot if i provde cooling to hopfully keep below 85 degC?
With regard to your L297/ 6203 driver do your motors buzz whilst hold?
Also have you got the contol pin set high or low?
D'uh
I've never run a stepper past comfortable to touch, usually lukewarm to tepid. Am I not trying hard enough :naughty:
Isn't there something about eddy currents heating things up? No possibility he's driving one coil with the other shorted out I suppose? That would be the perfect recipe for slow'n'hot :heehee:
Robin
04-11-2009 #4
Problem solved........:whistling:
It all went up in smoke tonite, flames an all. quite impressive :heehee:
Looks like I need a new 3 axis stepper driver.
2 steps forward 5 steps back eh.
05-11-2009 #5
05-11-2009 #6
Glad you found it funny.
I'm £50-60 out of pocket now to replace it tho
Could be arranged, and very tempting, but being a tight git i'm going to rob the heat sink ect from it first.:dance:Unless you chuck a bit of paraffin over it :naughty:
I cant find any cheap drivers that work over 40v so looks like I cant even use the psu.
05-11-2009 #7
05-11-2009 #8
I've done worse, not on the large hadron collider scale perhaps, but whaddya do? Personally I remind myself that it's business and in business you always start from where you are now.
OTOH, being business I do get to buy the cloud of smoke pre-tax and reclaim the VAT :whistling:
I understand your pain :nope:
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
