Thread: Help with drill-Mill conversion
Finally got some workshop time this evening and finished setting up the lathe. :dance:
Spent 30mins centering the quill in the 4 jaw chuck. What a nightmare!think Ive got it sorted now. (when I realised that 0.001" run out is F**k all) Ive drilled out the knockout slot to 10mm and created a start point for the tap drill.
The hole through the ER chuck is about 9mm , so the max bolt size I can use is M8, Problem is getting a drill bit and Tap that will reach the 150mm
required.......
Any one know of a source of long reach taps? or will i have to make up some sort of extension bar?
14-06-2009 #2
14-06-2009 #3Let me get this right... you're drilling out the quill to allow a draw bar through to pull the ER collet chuck into the quill... so what are you planning to tap? did I miss something?
Bill suggested drilling from the chuck end up into the quill and then use a bolt through the chuck to secure it (similar to some drill chucks)
So i need to to drill a 7.5mm hole in the quill and then tap it for M8, dose that make sense?
14-06-2009 #4
Can't you just put a fancy nut through the taper knockout slot and save driling anything?
15-06-2009 #5Can't you just put a fancy nut through the taper knockout slot and save driling anything?
Would a M6 be good enough?
Irving
Thanks for the info on inverters. just got one to play with
15-06-2009 #6
M5 even, so long as you use a good quality screw and key. HT would be overkill, just avoid stainless and cheapies.
If you buy a box of screws you could torque one to destruction in a piece of scrap. Then you'd know
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
