Thread: Help with drill-Mill conversion
09-06-2009 #21
Safe - maybe if you can hold it tightly - drills have been used as lathes by holding the tooling in a vice and the workpiece in the chuck (I've done it).
Accuracy, its hard to see how you'd get the drill absolutely in-line with the quill. Here's an idea tho.
Acquire a block of MS say 50mm cubed. Drill an M4 tapping hole through the center of one face and tap M4. Put the cube in the vice with the M4 hole horizontal and accessible through the side of the vice jaws then drill down through the centre of the face with the drill you want to use to drill the quill. Remove the drill and without moving the vice put the drill shaft in the hole and lock in with a M4 bolt.
Remove the chuck and lower the quill onto the drill... careful with speeds and use coolant if poss.
You might need to grind a flat on the drill shaft to locate with the locking bolt.
The accuracy depends on how square the chuck was to the quill initially...
So, JohnS, Robin, BillTodd, etc (as real engineers) where's the flaw in my suggestion?Last edited by irving2008; 09-06-2009 at 08:13 PM. Reason: spelling
09-06-2009 #22
I wouldn't call myself an real engineer, or indeed, any kind of engineer but...
That sound like a good plan to me :)
Ross, What's the end of the quill look like? e.g. does it have a centre spot from the taper machining operation?
Actually, your clever plan means the new drill 'chuck' will be properly aligned with the quill travel regardless of vice alignment.The accuracy depends on how square the chuck was to the quill initially...
09-06-2009 #23
Sounds good to me :clap:, have to scavenge a block of steel, sounds quite big. Ive got Al that size but suppose its not ridged enough.
Hope to make a start at the weekend, so ordering last few parts
Just looking at the uniport from DIY CNC (from a thread on here) , looks to to be perfect for a mill, is it beter than the opto board?
09-06-2009 #24
Bill
Didnt see your post as I was replying to the previous.
Cant remember, I'll have a look tommorow, Is this an issue if there is a centre spot?Ross, What's the end of the quill look like? e.g. does it have a centre spot from the taper machining operation?
09-06-2009 #25Just makes it easier :)Is this an issue if there is a centre spot?
09-06-2009 #26
Added thoughts...
Size of block = size of drill x 2-ish need enough metal for the locking bolt to remain rigid
If drill shaft < drill size (as it might be if its a big drill) then drill out the hole shaft sized first then use the proper drill to bore down 10-15mm to provide a locating seat... then remove drill etc as before....
Ally instead of MS... can't see why not, maybe go for a bit more 'meat' on it. Only issue might be getting a good lock on the drill... if you never want to use the drill again without some effort you could try loctite in the hole!
thanks for the +ve feedback
09-06-2009 #27
Hang on, reality check.
Just how long is this drill bit?
Sounds like it has to reach up through the morse taper, past the taper knockout slot and then all the way up through the quill?
You reckon this pipe auger is going to start on centre without some kind of guide bushing :heehee:
10-06-2009 #28
Uhmm. How do I say this.........
It dose fit in the lathe.
I forgot the splined end was narrower than the 20mm shank at the taper. Just fits in far enough, about 25mm projecting from the chuck.
SORRY,SORRY, SORRY
Not all the way through as this was the point, securing the collet chuck from the underneath, 90mm for the taper and knock out section + shank in chuck + depth of hole for new bolt thread. so long enough.Sounds like it has to reach up through the morse taper, past the taper knockout slot and then all the way up through the quill?
14-06-2009 #29
Finally got some workshop time this evening and finished setting up the lathe. :dance:
Spent 30mins centering the quill in the 4 jaw chuck. What a nightmare!think Ive got it sorted now. (when I realised that 0.001" run out is F**k all) Ive drilled out the knockout slot to 10mm and created a start point for the tap drill.
The hole through the ER chuck is about 9mm , so the max bolt size I can use is M8, Problem is getting a drill bit and Tap that will reach the 150mm
required.......
Any one know of a source of long reach taps? or will i have to make up some sort of extension bar?
14-06-2009 #30
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
