Thread: Help with drill-Mill conversion
21-06-2009 #51
Yup,
M8 is 1.25 pitch with 6.8 tapping drill.
7.0 mm will do in a push, that's the usual size for tough stainless.
Wouldn't have thought Machine Mart did specials like 1.5 pitch.
The reason it won't thread is probably because it's a crap tap, can you borrow one off someone ?John S -
22-06-2009 #52The reason it won't thread is probably because it's a crap tap, can you borrow one off someone ?A problem I've noticed with cheap tools is they aren't always the size they claim....I remember drilling the last hole in a big expensive job 18mm instead of 17.5mm caused me no end of trouble...New glasses fixed it ;)
M8 thread with a 1.5mm pitch?
I've been tapping a whole heap of holes for my recent CNC build. For an M8 thread with the more common 1.25mm pitch, a 6.8mm hole is the norm (you sure it's a 1.5mm pitch? as this might account for why your tap is getting stuck!)yeah the tap is 1.25 pitch
Thanks again and sorry for the duff info
With the stalemate on the quill I've been looking at the X-Y table, bit concerned with the flex in the 22mm rails and skate bearing arrangement on one side, and then making up some sort of T slot table.
For £80 I can get a cast iron compound table (not as big as I would have liked) or I can use some of my THK rails, but still need to sort a table.
Is 8080 extrusion ok for a table if the rails are bolted to it? Still want it to be as cheap as possible but realised that cutting corners still costs in the end.lol
24-06-2009 #53
Ok feed up with messing around and decided to take the advice of you guys (think it was the 2nd or 3rd post) and buy a compound table...:clap:
Got this one
http://www.axminster.co.uk/product-A...able-21825.htm
Free delivery is a bonus. Bit of work and it it should be ok. T slot tables of the same size where the same price, so at least I will have a decent table. If it works I will have only spent £100 as the drill was free and the other tools are useful for other projects
Extra long tap and suitable bolt also on order. Hoping it will all be here for the weekend.
28-06-2009 #54A problem I've noticed with cheap tools is they aren't always the size they claim....
Compound table is useable after all lot of rework. (Think it was cast, rough milled and bolted togother)
The bit I'm struggling with is eliminating backlash in the acme screw. I've Cut a slot and fitted a pinch bolt, but as the screw and thread are so rough the friction caused is not good.
My question is how critical is it to completly eliminate backlash or is the compensation in Mach able to overcome it?
I can probably improve the current state (about 2 or 3 deg. as a guess) but will take more time...
Photos soon If anyone is interested
28-06-2009 #55The bit I'm struggling with is eliminating backlash in the acme screw.
28-06-2009 #56How about using a Delrin nut instead of the brass(?) one (or a second nut made of delrin to remove backlash)
Wheres the best place to get ready made ones? as the thread is imperial (1/10 inch) Or is it still cheaper to buy a tap and make them my self?
28-06-2009 #57
I'd guess they'd be strong enough, although wear rate might be high.
I think one of the guys on the forum has been making and selling them (I don't know whether he has the correct tap for your threads)
What diameter are the lead-screws?
Are the nuts cast in place or are they removable?
Pictures would be good.
29-06-2009 #58
Ok you'll have to excuse the photos and the state of my workshop. For some reason if i dont use the flash then there not in focus..:cry:
The screws are 16mm dia. (15.65 on the calipers) and have a 2.54mm lead (imperial 0.1") Cleaned and polished the screw so thats looking better but just noticed the nut has cracked where I have been tighting the pinch bolt, so definetly need a new one, ups.
The nut on the x axis is removable and the y axis is fixed.
Ive had a quick look on tinternet and found lots of different ideas but I'd like to know If any one has a tried and tested method, I've fitted bearings to the screw which was a major improvement, so just need to sort out the backlash in the nut..
Hopefully when its finished it should be a good MILL.....
29-06-2009 #59
Screws are 5/8" x 10 tpi not metric,
Unfortunately 5/8" usually comes in 8 tpi.
Is it definitely an Acme screw or square thread, acme has tapered sides at 29 degrees ?
Then are they both RH, LH or one of each.John S -
29-06-2009 #60Screws are 5/8" x 10 tpi not metric,
Anyway they are square and both RH, y axis moves correct but the x is opposite to the lathe (clockwise rotation moves it towards you)
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
