Thread: Help with drill-Mill conversion
30-06-2009 #61
Square is square.
Acme is 29 degrees and usually imperial [ not always ]
Trapezoidal is 30 degrees and always metric
Let me have a look tomorrow to see what taps I have, definitely got 5/8" x 8 LH Acme but not sure on the rest.
.John S -
01-07-2009 #62
This rather depends on the accuracy you are trying to achieve.
The software can add extra travel when you reverse direction but that means the slides have to be tight enough to resist side forces from the tool so only the nuts can move them. Once the slides are set tight you have to worry about spring in the system.
Alternatively use two nuts. If you lock them together then wear becomes your problem. Spring them together with sufficient force to resist the tool pressure and you need monster size motors to turn 'em.
If it was easy to eliminate backlash with cheap screws nobody would sell expensive screws
01-07-2009 #6340 years ago men were sent to the moon. Most of the machines that built the rocket that got them there had backlash to some extent.My question is how critical is it to completly eliminate backlash...
The critical bit is reducing the backlash/play/give/flex/strain/vibration/call-it-what-you-like it the whole machine down to workable level and working the machine to reduce the effect of the errors.
The important thing it to lock them together with the smallest possible clearance. This can mean that, with a poorly formed lead-screw thread, the nut will be slack in places while tight in others (lapping the thread with a nut and abrasive e.g. metal polish can reduce the tight spots).If you lock them together then wear becomes your problem. Spring them together with sufficient force to resist the tool pressure and you need monster size motors to turn 'em.
01-07-2009 #64
Thanks for all the advice, Taken it all on board. From looking on here and the CNC zone I always planed to use servo motors, linear rails and ballscrews for the main machine, and now I know why.....
Still all good practice, dont know If I can justify ballscrews for this one. No point in having an ultra precise table if the head flexs all over the place. May be I should just get it working and then if its just the backlash thats an issue, I can sort it then.
Made the tap tonight and tried it on some plastic I had kicking around. Worked fine but I think the plastic is to springy and the tap wont cut the last bit for clearance, very tight over a 40mm length. Ive tryed tapping fuild and a drill but the end result is a very hot and shiney leadscrew, Still at least I know the best way to polish them now :clap:. I'll have to order some delrin,or try narrower sections.
Changing the subject, what is the best way to hone the dove tails on the slides? I've got them really smooth, with no play, except for the the first 30mm or so where i can feel an bump, Cant get the oil stone in and dont want to over do it by using a grinder.....If I carry on lapping it will both parts wear and then cause problems over the whole length?
Thanks again
02-07-2009 #65
02-07-2009 #66
02-07-2009 #67
02-07-2009 #68
You could try just lapping the parts together dry (i.e. degrease it and rub). Cast iron is fairly abrasive stuff so a few dozen cycles should polish the machining marks.
BTW Use proper 'way oil' e.g. Mobil vactra. (Keep that old can of Duckhams for the car use only ;) )
02-07-2009 #69No need to get personal.:heehee: Office workers can very usefull....making tea, sweeping the floor etc.If you want to scrape the ways then a scraper is the best way forward....made from an old file or similar.
Requires manual dexterity and mastery of hand tools....not for the office workers :naughty:
Unfortunatley its not just machining marks, there is a proper lump that needs removing. Still I'll give it try.You could try just lapping the parts together dry (i.e. degrease it and rub). Cast iron is fairly abrasive stuff so a few dozen cycles should polish the machining marks.
Is that a typo? or did you mean scrap itThe best tool to scrap it with is a grinder......
02-07-2009 #70Bugger, thought I had you then. Dont know how that happened! I'm normanally reeelle gurrd @ speiling ;o)Your typo? my implication :naughty:
No I havent, better find it and have a look, make sure Im not doing the same......Ever see the fanboy posts on cnczone where they all went mental and set about knocking the stuffing's out of their dovetails with grit lmao
All this oil is playing havoc with my manicured nails...lolYou got me on the making tea strike.....Can't call em completely useless eh :D
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
