Thread: Help with drill-Mill conversion
30-03-2010 #31
Or, maybe, too fast
Irving may disagree with this next bit :naughty:
There are published tables for cutting speeds but there are also tables for chip loadings. If you go for the official cutting speed the feed rates have to increase in proportion to keep the chip removal rate and up goes the side loading.
I simply don't have enough iron in my round column mill to hold against the side loading and smaller tools don't have enough meat to avoid bending. I reduce the revs and feed rates dramatically, I may be wrong but it works for me.
Get it wrong and first the tool digs in removing too much, then it rubs for a bit before the next dig in. Surface finish goes to pot.
When a tool starts to rub, rather than cut, it introduces a bending force. You can go around the finishing cut until the cows come home without fetching it to size. Increase the hole cut size to get past the rub and Whammo, you've cut oversize.
The trick is to rough out and leave an even excess all the way round the job then get the revs and feeds right on the finishing pass. Ignore the tables, find out what works on your machine. Even then the problems may come back when you change direction.
The routers of aluminium cut uphill, but they are usually making pretties rather than working to tolerance.
The millers of aluminium have a lot more rigidity in the system so they have can afford to cut downhill, meaning the tool shies away from the finished size rather than in to it. This does mean removing the backlash. If you compensate for backlash in the software you can't afford any side loading on the tool which can move the slides, a severe restriction on feed rates, and hence, spindle revs.
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
