Thread: Help with drill-Mill conversion
31-03-2010 #32
You must be a mind reader I was just going to ask about the tables for speeds and feeds........ Is it not worth me knowing what it should be so I can work back? where can i finf these tables?
I'll have to check the flexing, The quill was hardly down and the bit was 10mm dia, 20mm long in a ER32 collect chuck so I hope it wasnt tool flex. And im not sure how i can slow the spindle down without a major redesign and a shorter belt. I was hoping to check it worked properly before I bought a 3 phase motor.
Certainly shallower cuts and plenty of cutting fluid improved the surface finnish, just how noisy should a rough cut be??? maybe I'm erring on the side of caution.
I'll have to refresh my memory on up hill and down hill milling. I always thought that learning how to use it would be harder than making it :oD
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
