Thread: Help with drill-Mill conversion
01-04-2010 #35
Ok cutters arrived today, tryed the 6mm one and what a difference. 3mm deep cut in one pass with nice clean sides and no burrs on the edge. not sure on the cutting speed but the velocity is set at 400 mm/min. but the feed rate said 18mm/min I think . still need a bit more practice with mach.
You where definetly right Robin, I think I,m getting closer to the machines capabilities, althougth for what it is I'm more than happy with how it performed with the 6mm cutter. I'm sure that I can improve on the 3mm depth with a bit more tuning.
now its cutting clean edges It appears to be 0.3mm out, not sure if this is a step unit error ( had to round up to whole no.) or backlash. When I first tested it under no load I was getting 0.02 accuracy, is it possibly that the machine is still settling down? I dont think it can be machine flex as i was only typing the G-code line by line so it would have plenty of time to straighten up before the change in direction. I wont be to happy if the delrin nuts need constant attention tho...
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
