Thread: Help with drill-Mill conversion
09-06-2009 #11
Safe - maybe if you can hold it tightly - drills have been used as lathes by holding the tooling in a vice and the workpiece in the chuck (I've done it).
Accuracy, its hard to see how you'd get the drill absolutely in-line with the quill. Here's an idea tho.
Acquire a block of MS say 50mm cubed. Drill an M4 tapping hole through the center of one face and tap M4. Put the cube in the vice with the M4 hole horizontal and accessible through the side of the vice jaws then drill down through the centre of the face with the drill you want to use to drill the quill. Remove the drill and without moving the vice put the drill shaft in the hole and lock in with a M4 bolt.
Remove the chuck and lower the quill onto the drill... careful with speeds and use coolant if poss.
You might need to grind a flat on the drill shaft to locate with the locking bolt.
The accuracy depends on how square the chuck was to the quill initially...
So, JohnS, Robin, BillTodd, etc (as real engineers) where's the flaw in my suggestion?Last edited by irving2008; 09-06-2009 at 08:13 PM. Reason: spelling
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
