Thread: Help with drill-Mill conversion
14-06-2009 #11I decided against drilling all the way through the quill as I could only get a 6mm hole through the splined section and the chuck needs M10, resulting in a long thin drawbar and some sort of thresd adaptor.Let me get this right... you're drilling out the quill to allow a draw bar through to pull the ER collet chuck into the quill... so what are you planning to tap? did I miss something?
Bill suggested drilling from the chuck end up into the quill and then use a bolt through the chuck to secure it (similar to some drill chucks)
So i need to to drill a 7.5mm hole in the quill and then tap it for M8, dose that make sense?
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
