    Re: long drill and tap - quick n dirty fix
    In your lathe with the appropriate tapping drill (6.8mm?), drill into a length of 3/8" bar , grind a small flat on the drill, insert it into the bar and dot-punch into the flat - it should hold well enough to drill into the quill
    Similarly, drill a hole just small than the square end of your M8 tap and hammer the tap into it .
    Now you tell me.. cheers any way. may still need to do that.
    Attached some pics of the progress so far. My brain must be playing tricks on me, I could have sworn it was 125mm last time I measured it. M8x100mm bolts on order, so see how it goes.
    Seen a few other modded drills on the net and the ones that seem to work are like mine, with the X-Y table mounted on the base(lose the flexible table) and then lower the head to suit.
    There will be no going back once I cut the pinch groove in the head casing..
Name:	Quil & Chuck2.JPG
ID:	523   Click image for larger version.
Name:	Quil & Chuck.JPG
  1. FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
    Last Post: 04-08-2013, 10:30 PM
  2. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  3. WANTED: Small CNC Drill/Mill
    By Mad Professor in forum Items Wanted
    Last Post: 03-09-2010, 01:28 PM
  4. Is it possible to modify a drill to be an end mill?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 29-04-2010, 02:51 PM
  5. Drill/Mill Spindle brake (RF30)
    By BillTodd in forum Machine Discussion
    Last Post: 04-11-2009, 12:09 AM
