Thread: Help with drill-Mill conversion
08-07-2009 #11Just like the nut, there should be a tiny amount of play in the gibs (you can always tweak it once it's up an running, so leave them a little slack). If they're too tight it'll cause you as many problems as too loose.and Ive also got the gibbs set to tight.
Does the table slide freely now? There'll be an initial stiction (about 40lbs worth on my drill/mill) but, once moving it should move easily.
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Drill/Mill Spindle brake (RF30)
By BillTodd in forum Machine DiscussionReplies: 12Last Post: 04-11-2009, 12:09 AM
