my way would be if the Dia 6 mm need to be precise (by hand does not work)
mill the part with the Square 5
make a 4,5 thick nest that should be fit to the lower portion
fix this nest into a fix part of the vice so you already have fixed in the three planes -the center line of the dia 6mm vertical
fix the part in the vice -take a null point in the middle of the diagonals( only at first pc)
make the dia 6 with helix mill
you only need to change the piece carefully and push the green button
(sorry but do not know what means you have)
09-12-2014 #2
I use my friends router, my first build, which is not a mill, but is very precise/0.01mm and still continues to surprise me/
Ok, i get it. I haven't thought of that. So what you say is mill a bed, and then one by one fix them, flip them and mill them. Horizontally yes? Sounds better than lathe and simpler. or you mean the part to be vertical and do it at once? Wouldn't it vibrate like that?
As far as i understand you mean to make all this vertically, so i open the vice
PS:
The 6mm goes into triple bearing, so not that the diameter is so important as the center line of the piece, cause it must rotate dead on its center/2.5mm/ other wise when the bearings are encased, it will try to move them differently and friction will occure
09-12-2014 #3
Depends on what you have now:
If you do not have material the best seems from 8 mm thick material- horizontally do all with chamfer (upper figure)
flip mill back to 5 mm chamfer ready-problem the r2 radius
If corner must sharp you need to do the first step or rough then flip to vertical and do the helix or only remove the radius(lower figure)Last edited by vargai; 09-12-2014 at 02:49 PM. Reason: new option
The Following User Says Thank You to vargai For This Useful Post:
09-12-2014 #4
09-12-2014 #5
At answering I put this into your quote and maybe not noticed:
Vertically yes but I have not thought to do square 5 and dia6 in 1 step, however it may work -you now as you go down with the mill you have the wider cross section down along the Z path so the 5x5 mm does not have affect to resonate-I think in alu should work especially on your machine
If you can - try this too -I am wonder if this works- perhaps this would be the fastest with chamfer on the wider edges instead of radiuses (1 step all what I can see in your dwgs)
Roundover finishing - what's causing this..?
By Wal in forum Woodwork DiscussionReplies: 4Last Post: 18-03-2014, 03:37 PM -
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
Need some ideas
By jpcnc in forum Machine DiscussionReplies: 20Last Post: 29-01-2011, 07:56 PM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
