Depends on what you have now:
If you do not have material the best seems from 8 mm thick material- horizontally do all with chamfer (upper figure)
flip mill back to 5 mm chamfer ready-problem the r2 radius
If corner must sharp you need to do the first step or rough then flip to vertical and do the helix or only remove the radius(lower figure)Last edited by vargai; 09-12-2014 at 02:49 PM. Reason: new option
The Following User Says Thank You to vargai For This Useful Post:
09-12-2014 #2
09-12-2014 #3
At answering I put this into your quote and maybe not noticed:
Vertically yes but I have not thought to do square 5 and dia6 in 1 step, however it may work -you now as you go down with the mill you have the wider cross section down along the Z path so the 5x5 mm does not have affect to resonate-I think in alu should work especially on your machine
If you can - try this too -I am wonder if this works- perhaps this would be the fastest with chamfer on the wider edges instead of radiuses (1 step all what I can see in your dwgs)
Roundover finishing - what's causing this..?
By Wal in forum Woodwork DiscussionReplies: 4Last Post: 18-03-2014, 03:37 PM -
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
Need some ideas
By jpcnc in forum Machine DiscussionReplies: 20Last Post: 29-01-2011, 07:56 PM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
