Thread: Use of epoxy for levelling
16-03-2015 #1Yes I forgot that bitThen when you think it's cured check the test piece by bending, if it just bends and doesn't snap then your not cured enough, if it snaps then your ready.
.. Clive
16-03-2015 #2
I wonder if anyone has tried polyurethane casting resins instead of epoxy for levelling?
The stuff i have used in the past ( for casting not machine levelling) has the viscosity of milk and is designed to run and fill all the voids in a casting, i would imagine it would be better than most of the epoxy resins i have come across.
Its tough too and will take fillers and reinforcements if you want to use them.
http://www.benam.co.uk/products/plastic/
just a thought...
16-03-2015 #3
Thanks Clive, I will go back and edit, so it's clear that I am talking about the threaded bolts. The residual meniscus would be of a nominal thickness using this method and subject to removal once the drilled hole was opened out.
These guys might be worth a shout: epoxies start at page 58: http://www.swiss-composite.ch/scs4/h....shtml?lang=en (selling on behalf of: http://www.r-g.de/en/ ) I've never had cause to deal with them directly, but they are known to have a good reputation. Supplier to light aircraft industry, so quality is a priority.
Using the west system 105/209 as a point of reference, viscosity of the mixed resin @ 22oC is 650mPas. This figure will increase as the temperature decreases, so the resin will become more viscous, the lower the temperature gets. Minimum recommended temperature for the 209 is 18oC. Physical properties once cured are really important, so its good to have this datasheet as a reference point.
Possible alternatives:
- low viscosity resin system 100 mPas @25oC, cures at 10oC
- low viscosity resin system 250 mPas @25oC, cures at 15oC
There are some other low viscosity resin systems in there, if your ambient is higher.
Jazz, you're waiting 7 days? You're not adding any heat, not even ensuring a consistent 15oC?Last edited by Rich; 16-03-2015 at 10:24 PM.
16-03-2015 #4
How do you get that I never added any heat or kept a consistant Temp just from me saying waited nearly a week before fitting rails.?? . . You know what they say about Assumption.!!
My workshop is fully heated and Temp controlled with a Thermostat. The frame was slowly brought to room temp of approx 17deg over 3 or 4 days before applying epoxy and then workshop was kept at this temp for constant 3 days 24/7 afterwards then rails fitted after 6 days of curing.
This was using West systems 206 Slow hardener not 209 but still it caught me out, which I should have known better after doing several machines with epoxy.
17-03-2015 #5
From experience I know my elevated cure resin will harden in cold well, just add time. Excluding the 205 hardener, a workable cure should be achieved within 2.5 days (72oF cure is 15 hours max, 67oF equates to 30 hours, 62oF should be 60 hours). They quote 'thin film'. It tends to be 1mm or so. Thicker films, shorter time periods. I guess you must have been unlucky, or the hardener is getting old.
Matthewb,
I agree, polyurethane has potential with some additional benefits, including vibration dampening. I had a quick look at the website you posted. There were some reasonable numbers, attractive numbers on shrinkage, however, they tend to require elevated post cure. Quite expensive in my opinion. Have you thought of looking to the industrial floor coating industry - they might entertain a few free samples. Help you get your eye in before you pour.
Just noticed this website: http://www.resins-online.com/ I'd contact the underlying manufacturer for clarifications.Last edited by Rich; 17-03-2015 at 02:07 AM.
17-03-2015 #6
17-03-2015 #7
Lets be getting real here.? Epoxy method isn't rocket science and doesn't need to be made so.!! . . .It's just a matter of using correct Resin/hardner mixing it correctly and applying in clean enviroment at sensible tempreture with-in Manufacturers recommendations. . . THEN . . . Leaving alone until it cures FULLY.
By far the Hardest part for most is being patient enough to leave for couple of weeks but it really is best if your unsure because if rails are bolted on and they Sink it's all been for nothing and correcting is hassle.!
Silyavski as highlighted some good points and made sensible suggestions which for anyone building a Large machine with lots oof expensive epoxy would do well to follow but for smaller machines where Epoxy settles quicker and easier to handle then it really is quite simple if some common sense is applied.!
Clean, Warm, Dry with leak free dams and it's a doddle. .
18-03-2015 #8
Jazz, so you're saying the epoxy method, as described by Clive and Silyavski is the best way to go because it achieves what level of accuracy?
18-03-2015 #9
Let me respond instead.
It achieves the level of accuracy of your straight edge + your intention of accuracy.
You need a straight edge that should be at least as long as your machine is wide, to check the result and later square the gantry. Your intention of accuracy will help you see small mistakes if any and using shimming and checking against the edge will help the desired accuracy. Anyway you will need the edge to mount the rails straight in the other direction. The more accurate you want it to be, the more you will check and adjust and generally the more time it would take you.
For an example i did 3 separate pours of epoxy on my 3m long rails, when happy with the epoxy i mounted and dismounted 2 times the left rail and 4 -5 times the right one until i was happy. It took a week with helper, only adjusting the rails. The only reason to do that was because i will use that machine to surface other smaller machines and gantries in it and not mess in the future with epoxy
if not building something huge. If this machines purpose was not meant for that, i would have shimmed the first unsuccessful pour and finish with that stage.
So if you mean all day doing precision aluminum milling is one thing, other thing is if you do all day wood.
Even so, the bigger the machine the difficulty to achieve precision multiplies. It not only the epoxy, it how many times you check all and if you take your time to repair all that you have found.
Its difficult to explain but at the end the precision of the machine depends how precise are you or how precise you want it to be. All else is means and ability to achieve it.
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
Epoxy pouring advice
By cncJim in forum General DiscussionReplies: 12Last Post: 18-02-2014, 05:25 PM -
Epoxy cast plastic injection tools
By gavztheouch in forum Moulding MachinesReplies: 0Last Post: 27-01-2014, 11:33 PM
