Thread: First design - Few questions
01-01-2015 #8
Yes they are well OTT has my recent little rant tried to highlight for new users just like you.
If your into engineering then you'll have a good idea of whats required material strength wise so just apply common sense. The things to think and design around are resonance, flex along with plenty of adjustment built in to account for the DIY factor.
The most important area and under estimated is the Z axis. It's at the sharpe end taking all the cutting forces directly so any weakness here will show in the finished work.
Going back to the Z axis and cutting forces. The spindle power is key to balance and all those OTT engineered machines you've seen are under powered in the spindle department, by long mark in many cases. That is just waste of money, resources and time IMO which actually reduces the machines capabiltys not improves. IE: Lower acceleration or rapid feeds.
For a serious DIY machine that will cut everything upto aluminium and do it for lengthy periods then don't use a Kress spindle. They are toys in comparison to the chinese Water cooled spindles and not much cheaper.
Weight wise then 3 or 4Nm nema23's with the correct drives and voltage using ballscrews and profiled linear rails will be ok upto 70-80Kg Gantry and give good speeds with correct pitch.
Regards your design then don't hold back post it up for us to see. It's the best way to iron out any grey areas.
I'm not a fan of wood machines for several reasons which have been said but what you have to consider is the main use of the machine. If soley or mostly Wood use then it will be fine if designed correctly. It won't be cheaper than steel thou and much weaker.
If your thinking to cut aluminium then just plane forget using wood it just won't work reliably over time and be repeatable. Cutting Aluminium correctly takes the machine into another level. Yes most any machien will scratch it away but thats not cutting and does take it's toll on machine and tool life if not designed for it.
For a first machine I'd recommend you concentrate on the wood use only and build it the best it can be to do that.
Go for it and DONT let those Massive builds put you off it's NOT REQUIRED.!. . .
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
Some design questions
By cropwell in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 08-06-2014, 03:07 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM
