08-11-2016 #41
08-11-2016 #42
09-11-2016 #43
30-12-2016 #44
Hi everyone
Finally done the first cuts with the machine! I have a video posted on Youtube https://www.youtube.com/watch?v=TvKm...ature=youtu.be which shows the baseboard being levelled. I'm using a 1 1/8" (29mm) diameter bottom clearing bit @12000 rpm and 3000 mm/min feed and first pass at 0.75mm and finishing pass at 0.25mm
I did'nt realise how much dust would be created, so the next job will be the creation of a dustboot for the spindle and a cyclone filter system. I initially used my trusty Aldi ash can filter, but it soon got clogged up with the fine MDF dust. It will work better behind a cyclone system.
Also, I hooked up the Huanyang VFD to Mach3 using the VFD plugin by Sebastien here
This worked first time, but when I tried cutting in anger I got and e-stop near the end of the first cut, so had to abandon it and set the spindle by hand. I'm sure the problem is due to some electrical noise somewhere so need to add an EMI filter to the VFD and earth the shield on the RS485 connection to PC running Mach3
Overall really pleased, but still spending money on this.
Thanks to all you have advised me over the years (Jazz, Jonathan, John, Lee and others) and those who have encouraged me in the build (routercnc, kingcreaky, clive s and others) . If I've missed you off the list - i'm sorry - your help has been appreciated! - I'll have more to show in the coming weeks
Regards
MikeLast edited by MikeyC38; 30-12-2016 at 02:56 AM.
The Following User Says Thank You to MikeyC38 For This Useful Post:
30-12-2016 #45
😁 nice one Mike, always good seeing the first chips (or dust in your case!!!) from a machine...looking forward to seeing more. You do know that you'll be constantly doing more bits to it don't you? I've just made an ali corner finder to go with my touch plates, next is dust shoe mk2 then a better mist/fog nozzle system, then web cam in dust shoe....it goes on 😁
The Following User Says Thank You to njhussey For This Useful Post:
30-12-2016 #46
30-12-2016 #47
Hi Jazz
Yes it has been a long slog as you and I well remember! Thanks for the tip on earthing the machine. Should I earth it to the star earth I have in the control box (all shielded cables from machine to control box star earthed) or run it back to the mains earth?
Regards
Mike
30-12-2016 #48
30-12-2016 #49
30-12-2016 #50
Thanks Jazz I'll try that first before getting the EMI filter
Sent from my KFTT using Tapatalk
Setup for squaring twin X-axis gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 26-03-2014, 11:13 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
NEW MEMBER: New Member build finally started in Oxfordshire
By pjchick in forum New Member IntroductionsReplies: 1Last Post: 26-11-2010, 04:02 PM -
BUILD LOG: Flying Gantry Build Diary
By geoff.sim in forum DIY Router Build LogsReplies: 8Last Post: 29-05-2008, 02:53 AM
Well done Mikey know it's been long slog but you done it correctly and you'll soon start reaping the bennifits.
so that I can get tool changes consistent and touch plates. These items improve productivity.
