04-10-2016 #10
Which to use or how well one works over the other moslty depends on the width of machine and like Clive mentions what your cutting.
The cut off point for me is anything wider than 600mm cut will bennifit from twin screws/belts. 600-400mm is open to usage to which is best. Less >=400 then single screw is fine unless mostly cutting Non ferrous metals then I'd go twin every time.
The Following 3 Users Say Thank You to JAZZCNC For This Useful Post:
Setup for squaring twin X-axis gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 26-03-2014, 11:13 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
NEW MEMBER: New Member build finally started in Oxfordshire
By pjchick in forum New Member IntroductionsReplies: 1Last Post: 26-11-2010, 04:02 PM -
BUILD LOG: Flying Gantry Build Diary
By geoff.sim in forum DIY Router Build LogsReplies: 8Last Post: 29-05-2008, 02:53 AM
