Thread: combination machine.
If you want a combination machine have a look at this site http://www.vicious1.com/ I did build but the cnc router is only good for wood and plastics probably suitable for what you need though. It is all put together with Arduino and Ramps 1.4 but uses Estlcam very succesfully with repetier firmware for Routing. Loads of videos available on You Tube if you search mostly printed CNC. If you are interested I have a bundle of parts from the one I disassembled you can have if you pay the postage, you will just need some 25mm conduit and the other hardware all cheap enough on Aliexpress if you're patient enough to wait for delivery.
23-02-2016 #2
Hi Lucan,
Thanks for the reply and offer of parts but at the moment I have put the rig on hold as I recently bought one of the mini lathes and I am spending my time building a steam engine the cnc machine is just sat on my kitchen table with just 2 micro switches waiting to be fitted on the X axis to complete it except for the micro switches it is ready to run all wired up set up to run under Mach3 software the site you put up looks like a great easy build, I just downloaded the software Estlcam that it shows on the Vicious1 site and it looks much easier to use compared to Mach3 so once I return to the machine I will give it a try.
Again many thanks for the advise and offer of parts.
Regards Poppy Ann.If a cluttered bench indicates a cluttered mind what does a empty bench indicate!!!!!! Albert Einstein
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
Best CNC Software Combination
By Ricardoco in forum CAD & CAM SoftwareReplies: 12Last Post: 29-08-2011, 12:57 AM
