Yes, the spindle should be inside the footprint of the 4 gantry bearings, this is the key diagram; http://www.cncroutersource.com/do-it...NC-router.html
The Following User Says Thank You to EddyCurrent For This Useful Post:
15-12-2014 #2
Thanks for the advice would this be a better design.
15-12-2014 #3
Hi Gregor
That setup would ensure you get the Z axis very close to the gantry and the motor should be positioned as near to the centre of the X bearings as possible.
Only problem i envisage is the alignment of the gantry rails, do have a solution to this ?
Regards
Mike
15-12-2014 #4
15-12-2014 #5
Hi
When you talk about the gantry rails are they the rails on the x axis,Heres a few new pics ,I have done all the metal work to scale on sketchup and the dimension's off the base are 860mmx720mm not including the end plates on the base. The gantry was made 730mm to allow for clearance for the plates for the ballscrews. As I say I want to try and make it as simple and easy to make with most off it made by welding so let me know if this design is a load off Cr@P
Well I assumed mekanik was talking about the Y rails, those actually on the top and bottom of the gantry cross beams.
Are you putting the Y ball screw between the two cross beams ? if you are it's been suggested to add a plate to the front to keep crap away from the screw. This means putting a slot in the plate to allow the bracket where the ball nut attaches to the Z axis to move across. like here; http://www.mycncuk.com/threads/6418-...8048#post48048
It also adds strength to the two cross beams.Last edited by EddyCurrent; 15-12-2014 at 11:21 PM.
15-12-2014 #7
Yes the Gantry rails, top one can be leveled as per the X axis ie with epoxy but you then need to align the bottom gantry rail to the top one.
Ancient CNC machine- advice needed!
By tom_65a in forum Machine DiscussionReplies: 6Last Post: 11-05-2014, 11:17 AM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
Never simple is it! Mach, machine halts
By Shinobiwan in forum Artsoft Mach (3 & 4)Replies: 27Last Post: 31-01-2013, 07:11 PM
