    thanks for the advice, I was going to make the z axis out off 10mm steel plate or should it be 19mm aluminium
    Steel would be stronger but heavier and the weight could be a disadvantage.
    The best advantage of using Ali would be if you use tooling plate so it is perfectly parallel so mounting the rails and spindle mount would be easier and more accurate.
    Hi
    Could someone please explain how you measure ballscrews and what fixing you need to order in order to fix the ballscrew.The ballscrew in the picture is the x axis off the machine and there is an end plate at each end welded to the frame . there is an outer and an inner measurement.
    Cheers.
Name:	cnc base finished with measurements ballscrew.jpg
    This is the 'standard machining', if you are going to use pulleys then ask for 'dimension F' to be increased to 30mm, that's what I asked Chai to do and he did it no problem and accurately.
    http://www.mycncuk.com/threads/4826-...2863#post32863
    BK and BF bearings are the usual choice, dimensions here; http://www.alibaba.com/product-detai...961879637.html
    Using that info you should draw it up in CAD to find the exact size you need.
    Thanks EddyCurrent
    Hi All
    I have spent most off the day thinking about this build and also been reading the build logs and I have had a go at a machine using timing belt and pulleys which would give me nearly the same working area as the first machine but the outer dimensions would be reduced.I have used 60mmx60mm box and underneath I have used 6mm plate. Because I am using 60mm box how would I fit the stepper motor as the shaft would not be long enough to go through the box and would I just get the ballscrew end machined to the acquired length to go through the box .Here's some pics the base might not be strong enough. All Advice most welcome.
Name:	cnc belt drive460x60measurements.jpg
ID:	14173   Click image for larger version.
Name:	cnc belt drive460x601.jpg
ID:	14174   Click image for larger version.
Name:	cnc belt drive460x602.jpg
    That design can't work.! How you going to connect to gantry.?
  1. Ancient CNC machine- advice needed!
    By tom_65a in forum Machine Discussion
    Last Post: 11-05-2014, 11:17 AM
  2. bit of advice needed for first mill
    By jmac80 in forum Milling Machines, Builds & Conversions
    Last Post: 06-04-2014, 10:59 PM
  3. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  4. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  5. Never simple is it! Mach, machine halts
    By Shinobiwan in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 07:11 PM
