  1. #14
    Hi All
    I have spent most off the day thinking about this build and also been reading the build logs and I have had a go at a machine using timing belt and pulleys which would give me nearly the same working area as the first machine but the outer dimensions would be reduced.I have used 60mmx60mm box and underneath I have used 6mm plate. Because I am using 60mm box how would I fit the stepper motor as the shaft would not be long enough to go through the box and would I just get the ballscrew end machined to the acquired length to go through the box .Here's some pics the base might not be strong enough. All Advice most welcome.
Name:	cnc belt drive460x60measurements.jpg
ID:	14173   Click image for larger version.
Name:	cnc belt drive460x601.jpg
ID:	14174   Click image for larger version.
Name:	cnc belt drive460x602.jpg
  1. Ancient CNC machine- advice needed!
    By tom_65a in forum Machine Discussion
    Last Post: 11-05-2014, 11:17 AM
  2. bit of advice needed for first mill
    By jmac80 in forum Milling Machines, Builds & Conversions
    Last Post: 06-04-2014, 10:59 PM
  3. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  4. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  5. Never simple is it! Mach, machine halts
    By Shinobiwan in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 07:11 PM
