    You only need to mount the rails top and bottom if they are the supported rail type due to the unequal load capacity of the open bearing.
    One advantage of the top and bottom mounting is that the Z axis can be closer to the gantry, i.e. less overhang of the spindle.
    HI
    I have been looking at designing the z axis and I have notice that on my gantry design the bottom off the cross section is only 110mm above the base and building the z axis will lower it by another 20mm if I use aluminium plate to attach to the Hiwin linear rails, My goal was to be able to cut up to 75mm hard wood,Do I need to raise that bottom beam up to achieve that ? I have put the measurement's in the sketch
Name:	Gantry scalethreescrewmotor1233.jpg
    The top and bottom mounting does pull the z axis closer but not by much and you still need to get a ball screw in there any way. Horses for courses i suppose, easy build or extra strengh.
    With regard to the diagonal bracing I meant the node as is in the connection point of all the beams. As you have shown them at 45 degrees then they start at a node a go to the midspan of a beam.
    If you think of it as a wire frame then where ever the main beams meet there is a junction then this is the node.
    Hi Ross Thanks for explaining that,I have changed the side rails in the pics what do you think
Name:	Gantry scaleonetop beam.jpg
    Yeah that's the badger. I actually meant the diagonals in the bed but that works as well.
    Here's my latest attempt at the gantry and z axis, I think if I can manage the budget I may be able to get the 4way loading bearings rails for the gantry but I haven't priced anything yet.the z axis is 230mmx120mm
Name:	Gantry scalethreescrewmotor1finish12345123.jpg
ID:	14139   Click image for larger version.
Name:	Gantry scalethreescrewmotor1finish123451.jpg
ID:	14138   Click image for larger version.
Name:	Gantry scalethreescrewmotor1finish123451123.jpg
  1. Ancient CNC machine- advice needed!
    By tom_65a in forum Machine Discussion
    Last Post: 11-05-2014, 11:17 AM
  2. bit of advice needed for first mill
    By jmac80 in forum Milling Machines, Builds & Conversions
    Last Post: 06-04-2014, 10:59 PM
  3. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  4. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  5. Never simple is it! Mach, machine halts
    By Shinobiwan in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 07:11 PM
