  1. #18
    What about for the bearings you bolt a piece of say 20mm aluminium plate on using 4 cap head hex screws (I've shown bolts) in counterbored holes, then you slide the carriage along to each end of the rail in turn, so you can fasten the plate onto the gantry using 2 bolts (or maybe 4) inserted from below. Or if you put the 2 bolts in first there's probably enough room to tighten them above the rail.
  1. Ancient CNC machine- advice needed!
    By tom_65a in forum Machine Discussion
    Last Post: 11-05-2014, 11:17 AM
  2. bit of advice needed for first mill
    By jmac80 in forum Milling Machines, Builds & Conversions
    Last Post: 06-04-2014, 10:59 PM
  3. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  4. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  5. Never simple is it! Mach, machine halts
    By Shinobiwan in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 07:11 PM
