Thread: axis movement jamming
15-12-2014 #2
I think you need to find if it is 'jamming', or is it the stepper motors playing up ?
First thing I would do is remove the stepper motors and turn everything by hand to try and see where the problem lies, you might then want to strip it down in a particular area anything you suspect has siezed or failed in some way. Upon reassembly you should check that everything is in line and square to each other, lubricate in accordance with manufacturer guidance. If it's still not right it's time to investigate the stepper motors, drivers and electrics.Last edited by EddyCurrent; 15-12-2014 at 08:42 PM.
funny movement on solidcam turning
By eamo1978 in forum SolidworksReplies: 0Last Post: 23-06-2014, 08:16 AM -
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Motors, pulleys & movement - not strictly CNC related...
By Rogue in forum General DiscussionReplies: 5Last Post: 20-09-2011, 11:05 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
