Thread: Small Gantry Router
08-01-2015 #15
Nah at this size don't bother using differant size screws just go with 16mm all round and use 10mm pitch for X & Y 5mm on Z axis.
Critical speed isn't an issue if using steppers as you'll never get stepper to spin above 3000rpm and have any torque left.
One reason for 16mm is the intertia is less so you can have slightly higher acceleration. Connect the motors to screws with timing belts and pulleys to help with resonance but the other reason is that if you find you need higher resolution or more torque then you can apply a ratio to increase.
10mm pitch gives a good balance of speed and resolution. 5mm is ok if you need high resolution but not so much speed. This is why 5mm on Z axis because resolution is more important in this axis. Also the larger 10mm pitch means the motor/screw is spinning half the speed of 5mm pitch for the same feedrate. IE: 5mtr/min on 5mm pitch=1000rpm compared to 500rpm for same feed rate with 10mm pitch.
This puts the motor in better place on the motors speed curve giving more torque while cutting and still gives half decent feedrates. It also means the screw is spinning half the speed so less chance of whip for same feedrate as 5mm pitch.!
For cutting woods and plastics correctly you'll definately want 10mm pitch on X & Y for the faster feed rates.Last edited by JAZZCNC; 08-01-2015 at 07:11 PM.
Cast aluminium gantry router
By jrcast in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-02-2017, 08:13 PM -
Please review this router gantry idea
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 34Last Post: 09-09-2013, 04:47 PM -
RFQ: RQF: Router Gantry plates
By lateAtNight in forum Projects, Jobs & RequestsReplies: 1Last Post: 27-12-2012, 04:56 AM -
BUILD LOG: Fixed Gantry Router
By lateAtNight in forum DIY Router Build LogsReplies: 24Last Post: 28-05-2009, 11:30 PM
