    Quote Originally Posted by GoBo View Post
    Thanks, defiantly going to have a look at these. ebay best place to start looking?
    kjn aluminium was the best place I found and the cuts were very accurate and square.
    Quote Originally Posted by charlieuk View Post
    Nah too expensive try Motedis. http://www.motedis.co.uk/shop/index.php
    Exactly same stuff and cut to same accurecy but much cheaper, esp the T-nuts etc.
    Takes slightly longer to arrive due to being in Germany but not much longer and worth the wait for the savings.
    I'm another MDF router builder/user. Fortunately, I bought the steppers/electronics with a view to building a better machine later so the biggest investment is largely reusable. However, the MDF (plus added steel supports to try to keep the bed roughly flat) and the steel tube/skate bearing runners didn't cost that much. However, they did largely influence the incredibly slow movement of the machine, due to lack of strength and rigidity. The only thing moving faster than the gantry was the MDF bed (and the gantry, and the Z axis platform) warping...
    Yes, it can work, kind of, but I'm not sure if it's worth it. It taught me a lot, and the biggest lesson was why I am now building a welded steel-framed machine. Welding (strong if not pretty) is not that difficult, and almost any welding problem can be fixed with a cheap angle grinder and rewelding. DAMHIKTIJKOK?
  5. #4
    yes looks to be about 20% cheaper as you have to add vat to kjn prices but maximum length is 2m however that would be fine for the above build. Still if he is in Leicester it can be nice to support local and would be very handy for picking up those few fixings you all ways forget
  6. #5
    GoBo's Avatar
    Lives in Leicester, United Kingdom. Last Activity: 27-10-2016 Has been a member for 9-10 years. Has a total post count of 19.
    I'll have a look at both, thanks guys.
  7. #6
    Aluminium cuts on my bandsaw just as easy as hard wood, it's no problem to work with in that respect, it goes a bit like chewing gum when you start machining it though, at least the way I machine it
  8. #7
    GoBo's Avatar
    LOL..
    Yer we do have the kit to cut Ali no problems. Unless bolting this stiff together is good enough then its the welding and joining that going to be the problem.
  9. #8
    I can't imagine you would need to weld the aluminium but that's no bother too, take a look at these;
    http://www.chronos.ltd.uk/engineerin...-from-chronos/
    Watch the video here; https://www.machinemart.co.uk/shop/p...rter-kit#video
