21-12-2014 #11
Hmm, so what qualifications do you think would be appropriate in this case?
05-01-2015 #12
Well in case anyone else has this question, an appeal on another forum was more helpful. The programming procedure is described on pages 57 to 59 of the manual. The maximum frequency tFr and the high speed setting HSP need to be set to your desired maximum speed in Hz. Turned out to be easy peasy.
06-01-2015 #13
Small correction - it's uFR for max frequency, not tFR. Logical I guess.
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
maximum deflection - sanity check
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 11-02-2013, 09:33 AM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM -
maximum amps
By petejw in forum General ElectronicsReplies: 7Last Post: 11-08-2009, 11:40 PM
