You need to change a parameter in the drive to override default 50hz max frequency.
Quick look at manual I think it's in "drc" menu and parameter code "tfr". Set it to 100hz or what ever you want then the up/down arrow on the key pad will let you go to that as maximum.
17-12-2014 #2
John,
If you're asking about that it makes me wonder if you have the motor parameters set up correctly.
Referring to this manual; http://www2.schneider-electric.com/r...g%20manual.pdf
It's always a good idea to start off with factory default settings, page 55
Then set up the motor parameters, Page 59 (ItH) and Page 62
As Jazz says the max. freq. parameter is on page 63
Also, Is the connected motor designed to run at that frequency / speed ? you don't want it flying apart or the bearings siezing.Last edited by EddyCurrent; 17-12-2014 at 10:26 AM.
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
maximum deflection - sanity check
By dsc in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 11-02-2013, 09:33 AM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Maximum length guideline for a standard 16mm ballscrew?
By WandrinAndy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 01-11-2012, 12:27 AM -
maximum amps
By petejw in forum General ElectronicsReplies: 7Last Post: 11-08-2009, 11:40 PM
