Thread: DC motor control
I have a 1 1/2HP DC motor on a lathe that has a manual veriac controller I would like to change to electronic speed control has anyone done anything like this and can point me in the right direction where to obtain one please.
Phill
24-12-2014 #2
There's some DC drives here; https://www.inverterdrive.com/group/...V%2f240Vac+1ph
but you would need to find out if your motor is compatible.
Or maybe you could replace it with an AC motor and inverter drive.Last edited by EddyCurrent; 24-12-2014 at 02:54 PM.
24-12-2014 #3
Thanks Eddy,
The motor and controller was new 2000 - 2001 so don't want to change the motor just the controller box as it's big at 350 mm square, the supply to NECO box is 240-250Vac and I think the field supply to motor was 170 - 180Vdc
Phill
24-12-2014 #4
These Parker drives are quite good, this one looks like a candidate, but needs confirmed first.
https://www.inverterdrive.com/group/...er-Drives-505/Spelling mistakes are not intentional, I only seem to see them some time after I've posted
Help for MOTOR 2.2 Kw and control board optimum BF46 milling machine
By BILLYBOUM in forum Optimum Milling MachinesReplies: 30Last Post: 07-02-2023, 05:02 PM -
Emco C5 spindle motor control
By GeoffV in forum Motor Drivers & ControllersReplies: 2Last Post: 19-03-2014, 04:20 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM -
motor control
By Phil Gravett in forum Motor Drivers & ControllersReplies: 6Last Post: 09-06-2009, 05:02 PM -
Motor control
By crazy horse in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-03-2009, 09:31 PM
