Joe,
Yes you're right, I see that Arc don't sell ball screws any more. I have ordered other stuff from Zapp Automation who seem to be very good, and they offer machining services for ball screws I think.
No, he doesn't use a stepper driven spindle. Nor does Tony I think? IIRC Tony uses an electronic lead screw driver - http://medw.co.uk/wiki/index.php?page=ELS+Price+List - which uses a spindle sensor and synchronises the z drive to it. Frankly I don't see the point when you can use a full cnc system for not much more money.
Mach 3 and LinuxCNC both accept spindle pulses and synchronise the feed for screw cutting. Cncyourmyford uses LinuxCNC as this seems to give better results, as it has two sensors, giving one pulse per rev to sync the thread, and a larger number of pulses per thread (e.g. 64) to monitor the spindle speed. His package includes a ready configured LinuxCNC image. I use Mach3 and so far haven't had much luck with threading, I'm going to try the Linux version sometime at least on the lathe. Mach has only a single pulse per rev sensor and can't cope very well if the spindle slows when the cut starts.Last edited by JohnHaine; 22-12-2014 at 10:32 PM.
The Following User Says Thank You to JohnHaine For This Useful Post:
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
single and 3 phase motor sizing and mounting ?
By Musht in forum General ElectronicsReplies: 5Last Post: 27-10-2013, 09:58 PM -
convert 3 phase to single phase?
By D-man in forum General ElectronicsReplies: 10Last Post: 06-04-2013, 12:16 AM -
Panasonic 3 phase driver running on 1 phase?
By gavztheouch in forum Motor Drivers & ControllersReplies: 2Last Post: 10-05-2012, 11:21 PM -
CNC Myford ML7
By croy in forum General DiscussionReplies: 0Last Post: 28-05-2011, 07:40 AM
