    Quote Originally Posted by Jconway651 View Post
    I'm planning on using nema 23's and had seen this kit over at CNC 4 YOU
    http://www.cnc4you.co.uk/Stepper-Mot...3.1Nm-x-2-Axis
    purely for ease of buying it all at once.
    Is there a better or cheaper way to do things, should i avoid either of these kit for any reason?
    The 3.1Nm steppers from CNC4you are excellent and seem to be the cheapest around, so I'd go for those, but the kit is not much use as the power supply voltage is only 36V. You want about 75V for the motors to perform well.
    Can you recommend somewhere that does suitable 75V supplies. Most hobby cnc sites dont seem to go past 36V.
    Will the difference between the 36V and 75V be that noticeable?
    Yes. You could build one or see this http://www.zappautomation.co.uk/elec...er-supply.html you can get it with a 12v or 5v integrated power supply ..Clive
  1. Replies: 2
  2. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  3. convert 3 phase to single phase?
    By D-man in forum General Electronics
    Last Post: 06-04-2013, 12:16 AM
  4. Panasonic 3 phase driver running on 1 phase?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 10-05-2012, 11:21 PM
  5. CNC Myford ML7
    By croy in forum General Discussion
    Last Post: 28-05-2011, 07:40 AM
