Thread: Walnut Vinyl Wrap - Good one?
20-12-2014 #1
I want to make a small speaker product from birch plywood and then give it a walnut veneer. To make the prototypes I am using real wood veneer but it would save me a lot of time to use a self-adhesive vinyl that can wrap around the whole cabinet in one length.
I used Fablon sticky-back plastic from B&Q once many years ago and it looked really cheap. However I saw the Cambridge Audio Areo speakers recently and although they use a wood effect vinyl they look really lovely! Great speakers too, if a little bass heavy.
Can anyone advise where to source good quality self-adhesive vinyl?
20-12-2014 #2
Don't do it, stay with the real wood veneer ; http://tannoy.com/residential/#!products_1520
You can buy ready veneered ply, or if you intend making loads why not get a price for outsourcing the veneer work then you just cut the panels out.
If it's the corners that are giving trouble maybe this video will inspire; http://www.finewoodworking.com/item/...s-with-a-twist
the bit I'm on about starts around 1:30 minutes in.Last edited by EddyCurrent; 20-12-2014 at 09:10 PM.
20-12-2014 #3
I make high priced speakers with real veneer if customers want them, but the aim of this project is something small that packs a punch and doesn't cost a high-end price. If the retail price is about £290 in a shop then every little added in material and especially time counts for a lot at the manufacture end.
Also vinyl doesn't need to look bad at all. Obviously I have some experience regarding quality speaker cabinets and I needed a good hard look to tell the Cambridge speakers were not real wood veneer!
P.S. I happen to think those Tannoy speakers are pig ugly! ;P Here is one of mine with solid walnut and white leather.
20-12-2014 #4
20-12-2014 #5
Hi Jazz,
You are probably right, but I notice they chose the very simple square cabinet probably to make it easy to wrap. A chamfered edge would cause less distortion to the sound but they didn't bother. I could put these small speakers I want to make in a vacuum bag if it helps... The good thing about being so small (the size of a DVD box-set) is that they will be easy to wrap without air bubbles.
20-12-2014 #6
Maybe I should turn this question around and ask: If you were to design a 11x18x10cm speaker box to be easily manufactured on a home CNC machine (no atc, but with vac bed) how would you go about it? Bare in mind how to finish it nicely.
I'll post up a picture of my prototype later after a bath.
20-12-2014 #7
20-12-2014 #8
Vehicle wrappers are where you want to be looking
3M Di-Noc is the gold standard wrapping material, hard to get smaller Qs of though:
http://solutions.3m.co.uk/wps/portal...I-NOCSelector/
Other brands by the meter:
http://www.mdpsupplies.co.uk/vehiclewrapping.asp
Used the cheap taxi wrap in white for a few ply things, works an absolute treat , vinyl finish in one hit, not 25 coats of paint.
Wrapping film ain`t your Dad`s Fablon, air release liners and flexible so wont rip at first curve, hot air gun is handy.
21-12-2014 #9
Thanks that is exactly the info I needed! I'll see what I can source.
28-12-2014 #10
My apologies for the delay in replying. Here are photos of the cabinets I have made for the prototypes. In these photos I have wrapped them in a 'DC Fix' vinyl finish and to be honest it looks pretty nice.
The issue for me is mostly the edges of the cabinet. If I try to wrap this finish around the edge I need to cut it at the corners so it never looks very neat. This is basically fablon. In this photo I dyed the edges of the cabinet and then cut the wrap flat to the edge. I think it looks nice, but it would be better if I could wrap the edges too, in a neat way somehow.
So my question - can Di-Noc wrap stretch around the edge so it doesn't need to be cut at the corners or is that asking too much?
RFQ: 2 x Headphone Amp cases machined from Walnut.
By SamW in forum Projects, Jobs & RequestsReplies: 8Last Post: 20-04-2013, 09:03 AM -
NEW MEMBER: Good aft one and all...
By Swarf in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:03 PM -
NEW MEMBER: Good day all!
By icedfusion in forum New Member IntroductionsReplies: 0Last Post: 07-10-2011, 08:38 PM -
is this kit any good
By deannos in forum General ElectronicsReplies: 6Last Post: 26-03-2011, 09:17 AM -
Test of new vinyl cutter
By evildrome in forum Tool & Tooling TechnologyReplies: 0Last Post: 17-01-2011, 12:25 AM
