13-01-2015 #11
Nice, I'm new to the field but interested in making a machine one day, may I ask are those rails or ball screws on the yaxis? i really like this design and would copy it if you care to share where to get them? and based on my logic i would say they are rails, so where do you plan on mounting the ball screws? or whatever would drive the y axis? thanks!
13-01-2015 #12
KC, nice job looks good looks like New Holland combine yellow to me, just don't paint the gantry green
18-01-2015 #13
finished. installed into my buddys work yesterday.
18-01-2015 #14
Brilliant, and such a quick build. Great stuff. G.
18-01-2015 #15
Just goes to show what can be achieved in a small amount of time. I see you didn't go with the lime green gantry
Well done. ..Clive
18-01-2015 #16
Brilliant build, you've built 3 fantastic CNC machines in the time I've been fanning around with mine ;)
18-01-2015 #17
Yes it's a great job, soon you'll be going into production.
19-01-2015 #18
Well done, as expected, ridiculously quick! Just one question - doesn't all the crap fall into your X axis bearing, mounting it that way around? Some kind of guard might be a plan?!
19-01-2015 #19
21-01-2015 #20
YEP!!!. Im working a anti-gravity machine.... or... mounting it upside down on the roof!...
Seriously; The extraction system will have a bottom rail to catch any falling dust.
my greater worry is the x bearings being used on their side...
* 60 x 60 x 6 and 100 x 60 x 6
* Yep threaded hundreds of holes (got w*nkers wrist!)
* I Dont believe any "nuts" are used.
Nobody has pointed out any faults?? I was expecting a wooping.... this is only techically mk1... mk2 Il learn from the mistakes on this one.
So; il be honest.
1.) The biggest mistake... I should of had the ends (both) of the X ballscrews threaded; so I could put them under tension. They do sag a bit under their own weight.
2.) linear bearings being used on etheir side? X???
3.) The Z movement is way too much... it probably only uses half of the travel available (so unnecessary weight on gantry)
4.) really needs twice as many bed support braces. The distance inbetween them in launghable... space for twice as many
5.) No water cooling yet for spindle in video
6.) No emergency stops; panic buttons etc
7.) Need to add proximity for auto-square; but where I had mounted the brackets didnt account for quite how tight the fit into the room would be. Il have to re-think.
Now thats out of the way; fitting a really noisy roller shutter door to my workshop/garage (just to wind up my new classy neghbours), and to allow me to squeeze my van in.
Im then spraying van; in workshop (old vw camper)
once thats gone; take delivery of my new bridgeport mill!!!! ssshhhh dont tell misses
then start building my new machine (like this one)
laser scanner cnc router mounted
By dazza in forum Probing, Digitizing & ScaningReplies: 9Last Post: 30-08-2014, 01:02 PM -
Z mounted 4th axis
By charlieuk in forum Linear & Rotary MotionReplies: 8Last Post: 30-04-2014, 04:31 PM -
wall cnc like the wall saw
By crossleymarko in forum Machine DiscussionReplies: 10Last Post: 25-03-2012, 11:24 AM -
wall and floor fixing am I the only one ????????????
By luke11cnc in forum General DiscussionReplies: 15Last Post: 30-12-2011, 11:45 PM -
CNC Wall art from JPG
By BJ- in forum Opportunities Available & SoughtReplies: 0Last Post: 29-01-2010, 03:06 PM
