26-01-2015 #30
First prize to this man.. .
For 8' your into 25mm screws minimum and has clive says motors & drives to match. Thou Charlie you are familiar with the motor/drives already as they are the Nema 34 and high power Kinco type you are using now.
What you can do to help ease screw whip is use higher lead on the screws and put ratio on them. So say 20mm pitch with 2:1 will give you same feedrate as 10mm pitch but with half the RPM on screw so helping to eliminate whip etc.
If for wood use then 25mm screws with 25mm lead and 2:1 ratio would work well as it will give decent feedrate/resolution for wood and suit slower spinning nema 34 motors better.
laser scanner cnc router mounted
By dazza in forum Probing, Digitizing & ScaningReplies: 9Last Post: 30-08-2014, 01:02 PM -
Z mounted 4th axis
By charlieuk in forum Linear & Rotary MotionReplies: 8Last Post: 30-04-2014, 04:31 PM -
wall cnc like the wall saw
By crossleymarko in forum Machine DiscussionReplies: 10Last Post: 25-03-2012, 11:24 AM -
wall and floor fixing am I the only one ????????????
By luke11cnc in forum General DiscussionReplies: 15Last Post: 30-12-2011, 11:45 PM -
CNC Wall art from JPG
By BJ- in forum Opportunities Available & SoughtReplies: 0Last Post: 29-01-2010, 03:06 PM
