24-12-2014 #15
Not Mad but not as easy has you think to do and keep a ridgid and accurate machine. The link eddy posted is to a 5 axis machine that is both expensive and complex to build, let alone generate G-code. Certainly not something I would advise any one new to CNC to dream about taking on for a first machine.!
The problem with rotating spindles is the accurecy needed in the rotation device to keep the spindle so it's perfectly aligned in 2 planes. Sounds easy to just flip the spindle horizontal then back again.! But in practise there's quite a lot of time invested in setting up your spindle so it cuts true in both X & Y planes and gives a nice flat bottom cut parallel to the bed surface.
So any spinning device will need to be very well engineered so it's repeatable if want any decent accuracy. Then you have the fact you'll need to spin it 90deg in 2 planes to be of any use which adds to the complexity.!!
While I see why or the appeal of what you want then NO it's certainly not something you want to be taking on for a first machine believe me.! . . . The machine design Eddy used is a good tried tested design with one exception in that it he should have listened to his uncle Jazz and made the top rails longer. . .
(Soz eddy couldn't resist) and used the end of the bed for clamping.!
Is anyone interested in cutting dovetail joints?
By Ger21 in forum Woodwork DiscussionReplies: 19Last Post: 29-09-2014, 01:33 PM -
Cnc router of woodworking and adevertisement
By grace chen in forum Manufacturer NewsReplies: 3Last Post: 18-12-2012, 02:58 AM -
wooden joints
By luke11cnc in forum Woodwork DiscussionReplies: 7Last Post: 18-10-2012, 11:59 PM
