    In light of this recent discovery. I have re done my basket.
    I use to use AM882 however, after looking around online someone mentioned the DQ860MA Driver being ok instead of the AM882. Im just worried about the lack of sensor less stall detection not being on the DQ860MA. Thoughts ?
    Apart from the drivers im pretty sure on the rest, however if anyone see a major mistake, please let me know.
    For the Z-Axis driven through the knee
    2m2280N High voltage driver
    Nema 34 - Sy85STH156-6204B 12.1Nm
    suitible coupler to go between the Nema 34 and the z-axis rod.
    For the x and y axis
    Nema 23 3Nm
    DQ860MA
    Custom Power Supply
    Coupler to go between Nema 23 and Axis drive.
    I use to use flexible couplers, however in this kind of situation i believe a solid coupler would be appropriate. I don't know of any good suppliers for solid couplers however Im pretty sure I can make them.
    Like this.
    Works quite well for a my uses.
    Some of the parts used
    Stepper motors
    http://www.ebay.co.uk/itm/German-Shi...E:L:OC:GB:3160
    Stepper driver
    http://www.ebay.co.uk/itm/Single-Axi...item2ed842f005
    Although I have blown 2 up. One was by turning the Travel handle while it Was moving.
    With careful treatment they now seem ok. I would like to try something better. May be a Gekko....
    Ball screws on X Y X
    I bought 2 Chinese Ball screws with 4 Ball nuts , and had the machine the ends to 16mm, then made suitable sleeves to fit the bearings.
    http://www.ebay.com/itm/2-anti-backl...:X:RTQ:US:1123
ID:	14322   Click image for larger version.
ID:	14323   Click image for larger version.
    Nice Job. Did you not consider higher voltage drives to run the nema 34 motors. ..Clive
    Quote Originally Posted by ZX12RUSH View Post
    Like this.
    Stepper motors
    Stepper driver
    Very nice looking build! So apart from blowing a few drives, any other problems?
    You asked earlier on about drive belts.
    Well this site from the UK seems to have almost anything you could want.
    http://www.beltingonline.com/rubber-timing-belts-40/
    John
    If you never try it, you will never know if you can do it !!
    Thank you all for the advice and help relating to this conversion. Here is where ive got to so far. I have managed to create a mounting system for the x and y axis drives. I have three nema 34 1600oz stepper motors. I have a custom ball screw to drive the quill. What I need to complete is the quill drive system. Im hoping to use the 2 Axis CNC to help create the parts for the quill drive. Things having been moving slow due to problems that occurred with the Chinese supplier for the Stepper Motors.
    I have attached a photo of the machine so far .
    EDIT
    Posted twice
ID:	14325   Click image for larger version.
ID:	14326   Click image for larger version.
    Quote Originally Posted by thorphar View Post
    Stall detect only works after 300rpm so it's not such a big deal for a mill. But what is bigger deal is how they handle resonance better and give smoother running motors. The DQ860ma are not as good in my experience so I wouldn't use them over AM882 or better still the updated EM806.
There are currently 16 users browsing this thread. (0 members and 16 guests)
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. Looking into converting my Mill to CNC
    By T0rnado69 in forum Emco Milling Machines
    Last Post: 14-02-2019, 12:46 AM
  3. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 07:48 PM
  4. CONVERSION: Warco VMC Turret Mill - CNC Conversion
    By antsals in forum Conversion Build Logs
    Last Post: 07-03-2011, 12:25 AM
  5. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 04:27 PM
