Page 3 of 3 FirstFirst 123
  1. #21
    I find it best these days to only learn what I need, and that means only when you get stuck on how to do something you NEED to do.
    First prize goes to this Man.! . . . . This is by far the best way to learn IMO. Doing like this means you retain most of what you learnt because it had meaning and substance. It also makes you more eager to find or solve the problem.
    In the past I've spent many many hours on the phone trying to help folks with explaining how to do things or worn my fingers to the bones writing long emails on the same subject. Only for maybe less than 10% to actually get retained.
    Now I've learnt that the best way for them to learn and retain 80% is to create a project and give it there best before contacting me. Doesn't matter how miserable they fail doing this it gives a good start point where 5-10% is learnt and retained before I get involved. Then we can work on what went wrong or how can be done easier or better. Also I do this by having them at the software or machine and working directly on the project. This technique works great and far more is learnt and retained in short period of time.
  2. #22
    Hi Jazz,
    I see the issues you mention. I think I will get my z axis adjusted first. I may then get BobCAD and see how I go the post processor is the first hurdle I see!
    I am pretty good if someone tell me how to do something I try and jot it down to refer to.
    Many thanks
    Suesi
  3. #23
    Looks like I'm in the good books at the moment
    Here's a good saying that's very true;
    I hear, I forget
    I see, I remember
    I do, I understand
  4. #24
    Quote Originally Posted by suesi34e View Post
    I see why you think only learn when you get stuck it makes a lot of sense. The only downside is I have so much to learn!
    No no no learning to use or build a machine is like eating a Elephant.? . . . Can't be done in one sitting and best done in small bites.!
    There is a simple process and sequence to running a CNC machine and learning is best done in the same sequence.
    Starting with CAD so get this learnt to a proficient standard first which you say you have done.
    Next comes CAM. This can be easy or hard depending on the software. Some software requires more input from the user for selecting Geometry etc which you use to define toolpaths.
    Better software will give more choices and options in cutting stratergies along with easier or more advanced Geometry selection techniques. Ie Auto hole selection etc. Nice but not required.!
    In general it's learning the quirks of each software for simple things like selecting geometry that takes the time rather than figurng out the cutting stratergies and all there options.
    Lastly comes Mach3. Often Mach3 daunts people but it really shouldn't because in practise and in basic usage form there's very little to using it after the machine as been setup. Which really has nothing to do with using the software for cutting and is kind of separate thing.
    There's basicly 3 stages to setting up and using Mach3.
    #1 Setup and define the machine so it moves the correct distance and controls any I/O (Inputs & outputs).
    #2 Second Define tool numbers and height offsets or fixture jig offsets. (if using any)
    #3 The main one.!! Load G-code file. . . . Place material, insert correct tool, define WORK zero coordinate press Cycle start.!
    In real world use there really is nothing to using Mach3 and it shouldn't daunt anyone. Obviously there are few other options and buttons on the Mach screen you'll want to learn and use but again nothing scary or rocket science.
    When you have your working procedure setup and working for you then it get's easier stiil. For instance you'll keep a tool table of your cutters in CAM that matches the Tool table in Mach3.
    So when you select say 10mm tool in Cam which you defined and gave a TOOL NUMBER then saved in your tool table. That same TOOL NUMBER is used in Mach3 so when the G-code file produced for your part and calls for T1 Mach knows the height offset and tool diameter for this tool and automaticly applies the height offset and any cutter compensation if called for.
    You do nothing other than make sure you put the correct tool in the spindle. CAM and Mach3 work with each other.
    Obously this only applies to those with Mills or machine which use tool holders which can define set consistant heights of tools that never change.
    For the rest of use who use individual tools not using holders then we don't bother with Fixed Tool offsets in Mach3 and set Z axis Zero each time we change tools.
    But in all this the process of actually cutting parts in Mach3 is quite simple really and shouldn't scare anyone.
    Learn step by step and you'll be ok.
  5. #25
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    posted in the wrong post ..Clive
  6. #26
    Stay off the amber Nectar Pisshead. . .
  7. #27
    Hi Jazz,
    Thank you for your reassurance and so much info it is very handy to me. I guess I have been very cautious so that I hopefully don't damage my machine or tools. I would hate to mark the bed or something like that as it is in great condition. I guess I will do just like you say start with the basics and learn step by step. The CNC side of things is tricky for me especially as I don't get to the machine all that often, not as much as I would like! Hopefully once I get going things will mesh together a bit and I will be able to start making little parts. I think I will feel a little better once I have a good simulator like that in BobCAD so I can get an idea of what should happen before I start.
    Tar very much for all the help
    Suesi
  8. #28
    This why it's always best to set the Z zero work coordiante in Mach3 higher than material so you can cut air if your not sure. This way only time is wasted not an expensive table or tool.!
    I'll PM you some details and I'll work with you if you like and go thru the steps slowly.
  1. Training / Self learning
    By manofgresley in forum Programmers Corner
    Last Post: 27-02-2014, 01:25 PM
  2. NEW MEMBER: Hello, my name is "Jordan"! Interested in learning how to operate CNC Machines
    By JordanMoseley95 in forum New Member Introductions
    Last Post: 05-12-2013, 09:41 PM
  3. A learning process
    By cropwell in forum Milling Machines, Builds & Conversions
    Last Post: 21-02-2013, 07:38 PM
  4. NEW MEMBER: Learning with MYCNCUK
    By Goran in forum New Member Introductions
    Last Post: 10-12-2010, 06:08 PM
  5. NEW MEMBER: Old timer, still learning, Virginia, USA
    By GerryR in forum New Member Introductions
    Last Post: 13-10-2010, 10:41 PM
