Thread: Q: 24V Line driver IC
Thank you for your reply.
From the ESS to the BOB, i would say <75cm, and from the BOB to the driver <50cm
So the ESS drives the Opto-LED on the BOB, which again drives the Opto-LED in the drivers. (This is coming from converting, from Par-Port, to the ESS)
Not sure if I can skip the BOB, and use the ESS directly to the Driver Opto-LED. But for convenience I kept them......
When you say "Ground-Loop" is that from the PE (Earth symbol) so all units PSU's, PC, VFD etc. to be grounded.
And/or
All the 0V pins on all PSU's: PC-PSU, 5-12-24-48V to have a common 0V
Right now all the PSU's are running without common 0V.
Best Regards, Bo Andersen.
01-01-2015 #2
It is very easy to forget that as soon as you add a metal enclosure you are not just wiring electrically, you are also wiring inductively.
Do you remember the old trigger operated soldering irons? They had transformer with lots of turns on one side and about 2 or 3 turns on the other shorted out by a thermocouple. The thermocouple received hardly any volts but massive current causing it to reach solder melting temperatures in a second or two and then miraculously stop on account of the fact that it was a thermo couple :)
Anyway the point is, you don't need a lot of turns to make a transformer, one will do. The easiest way to make a single turn transformer coil (earth loop) is to drill a hole in a piece of metal then put a wire through it. Pass an alternating current through that wire and current will start to flow around the rim of hole. Drill another hole nearby with another wire through it and you have a circuit. No nearby hole and it will merely start to warm up.
If you want to put wires through a metal plate I would suggest you knock one ruddy great hole, fill it with a Tufnol sheet then drill holes through that.
If you make sure that everything going in or out goes through the same hole it will all cancel out. Simples.
cutting a fine line
By cubikoman in forum Tool & Tooling TechnologyReplies: 6Last Post: 19-02-2017, 10:04 AM -
Does anyone know about CAD/CAM courses on-line?
By hoezap in forum Marketplace DiscussionReplies: 7Last Post: 04-12-2012, 12:26 PM -
Line fonts
By daveshorts in forum Computer SoftwareReplies: 4Last Post: 07-09-2010, 04:43 PM -
CamSoft is on-line
By CamSoft Corp in forum CAD & CAM SoftwareReplies: 1Last Post: 13-01-2009, 12:55 AM -
Mach3 / Laptop No line driver !
By bruce_miranda in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 11-09-2008, 05:42 PM
