I popped the file into draft sight and saved it as a DXF from a DWG.
I didn't do anything to it though. I really haven't got a clue with regards to programming etc and am just winging it at the mo with what I have got ! :-)
I have the program R unning now on larger scale and it's still angular curves so I'm presuming it's the G codes need sorting ?
how would I save a Gcode ?
Im running the boxford software that they issue now with no Mach 3 involved.
carl
28-12-2014 #2
Trying to attach DXF, i think it worked ?
28-12-2014 #3
It doesn't look like a dxf file to me
The Following User Says Thank You to EddyCurrent For This Useful Post:
28-12-2014 #4
Im lost Eddie.
Trying to generate a Gcode in Cambam. I thought I had sussed it but it wont save to DFX only as .CB and my boxford wont recognise the file !
28-12-2014 #5
Sorry Carl,
But I can't open the DXF file. I don't know the boxford software, so someone else would have to contribute towards a solution.
You are seeing the arcs as a series of straight lines because somewhere in the chain of events from drawing to machine movements, the code to move the miller has been reduced to a low resolution.
Does the boxford software take in the dxf file ?
It is frustrating but I have to pass on this one.
Rob.
The Following User Says Thank You to cropwell For This Useful Post:
28-12-2014 #6
I cant open that one in autocad either.
Sometimes long curves get broken up into smaller lines or if they are splines or so and they don't come out right when saved as a dxf I think.
Try loading the file back into cad then save it as a R12 or older version. Then reload it and save as a newer version dxf and try it again.
28-12-2014 #7
I think ive sussed it fellas :-)
I managed to generate a tool path using the cambam and have exported to DXF. Im running it now but the curves look a lot curvier than before so far :-)
28-12-2014 #8
I was just going to say, in CamBam you have to use; File --> Export --> to DXF
28-12-2014 #9
Its just finished its program. still looks wrong
Boxford 125 TCL Searching for machine problem
By dragon in forum Boxford LathesReplies: 1Last Post: 28-12-2014, 09:27 PM -
Heiz Machine Problem!
By AllMightyBlue in forum Heiz CNC RoutersReplies: 7Last Post: 10-09-2014, 04:18 PM -
Location of machine problem
By Eugene in forum Computer SoftwareReplies: 2Last Post: 27-01-2011, 07:00 AM -
Machine problem. Heiz. Blew up on me !
By xchipx in forum Heiz CNC RoutersReplies: 2Last Post: 03-04-2009, 01:08 PM -
Machine Problem - Rockcliff
By Lee Roberts in forum Machine DiscussionReplies: 24Last Post: 19-02-2009, 04:49 PM
