    Hi Guys my 1st post.
    To start i know nothing about cmc machines, please bear that in mind.
    I run a sign company and in the past have used the zund cutters with the camera for cutting prints from a flat bed printer etc.
    Im toying with the idea of getting a cnc for cutting various materials to be printed on etc.
    my requirements would be
    able to cut 8x4ft sheets
    various grades of foam board 3mm, 5mm, 10mm
    aluminium composite sheet
    acrylic sheet various depths 3mm, 5mm, 10mm
    nothing to fancy cuts, just things like letters square cuts etc.
    whats my options as i want to spend as little as possible as id like to upgrade to a machine with a camera at some point..
    is there basic budget machines available or would a chinese machine be suitable, to be honest i don't know where to start...
    thanks in advance
    nick
    Lee Roberts's Avatar
    Lives in Milton Keynes, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,985. Received thanks 247 times, giving thanks to others 824 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hi Nick welcome to the forum.
    I'm not really sure on how to advise you, so first question is...
    Do you want to build your own machine or buy something commercially available?
    .Me
    .Me
    I would just buy something off the shelf really I'm not into building stuff, I'm quite handy with my printers etc, but wouldn't want to attempt anything like that..
    Quote Originally Posted by slinna View Post
    Hi Nick.If in China. A suitable price can fit your needs.Because it is a competitive market in China for so many factories.You can go to alibaba and made in china to search what you need.It is not easy to cut both aluminium composite sheet and other non-metal materials on one machine. Normally needs two cutting machines. Can you tell me what's your cutting accuracy? and how many do you need to cut for one day? Maybe I can help you.
    Hi, for accurcy, if i cut a board for instance 500 x 500 i need it to be that size generally, you can cut aluminium composite with a knife its not thick at all, is it possible to put a knife on these cmc machines ?
    I wouldn't be using it on a daily basis maybe a few times a week
    Think alloy panel OP refers to means Di Bond and similar
    http://en.wikipedia.org/wiki/Sandwich_panel
    usual to rout V slots for folding in it.
    Oscillating knife used for correx/twinwall
    http://en.wikipedia.org/wiki/Corrugated_plastic
    But thought that was a reasonably strightforward attachment in place of spindle?
    What are the problems with knives on CNC machines?
    Thanks!
    AXYZ 6010 3x2 meters Great condition, Must See!!!
    Gerber System 48 Plus CNC Router For Sale
    Thats Cheap especially if you want full solution. So you can start right away making money.
    There's no prices on any of those machines Boyan so how do you work out they are cheap.?
    Locust.
    Problem is that at the size you want and with the type of material you want to cut then you'll most likely need vacuum to hold down material.
    High volume vacuum pumps are not cheap esp for the size your wanting so trying to do this on a budget will be difficult.
    The machine required for your needs could be built resonable enough but a good vacuum system could cost nearly the same amount.!
  9. #8
    Sorry mistake, i was assuming they could be had for cheap when you have the cash in the pocket, as they seem complete solution. Anyway, the prices for second hand machines like these are quite clear, at least to me and as you say building it could cost almost the same, with the addons for production i mean.
    Hi Locust
    I imported mine, it's a 1325 machine that easily takes a full 8x4 sheet have cut mdf, ply, foamboard thin plate, hardwood so far. With the purchase plus cargo, import duty and vat it cost me around 7000 Euros. Came with 3hp 4 bag dust collector and choice of control system. I got the DSP very easy to use, does all that I need it to.
    Good luck
    Alan
  11. The Following User Says Thank You to alboy For This Useful Post:
  12. #10
    Thanks everyone for your replys, most helpful..
  1. wood sign cut with cnc router
    By jonm in forum Woodworking Project Showcase
    Last Post: 09-06-2014, 08:05 PM
  2. Looking for advice on budget machine for watchmaking
    By lanky_streak in forum Marketplace Discussion
    Last Post: 25-09-2013, 10:59 AM
  3. My first sign
    By Web Goblin in forum Metalwork Project Showcase
    Last Post: 03-04-2013, 09:05 PM
  4. NEW MEMBER: IT/Sign Maker/Geek
    By daverowland in forum New Member Introductions
    Last Post: 12-07-2012, 10:07 PM
  5. New to CNC: Best way to generate the g-code for this sign
    By drphil in forum Computer Software
    Last Post: 07-03-2012, 09:35 PM
