Thread: Keeping hywin rails clean?
31-12-2014 #2
Could you rebuild the machine with the rails & slides under the bed so that material will tend not to contaminate them and debris will "fall off" rather than "fall onto" the rails?
01-01-2015 #3
due to the nature of the foam chips created (they are bits rather than fine dust mainly) the shapes I am cutting and the static nature of foam is much as I would love to be able to remove it all at the source I think it is wishful thinking and that there will all ways be a small amount wanting to escape. It is only really the bottom rail that is getting badly effected and that is a real concern but it would be good to have some protection on the others. I like the idea of a positive pressure shroud although could be tricky to make and would it be that different to just blowing it off?I have tried putting brush stips on however due to the complex shape of the rails it is very hard to get complete coverage around the rail.
Has anyone used the hiwin dust proof kits? maybe it would do the job on its own?
http://www.wmh-trans.co.uk/Products/SIZE_20
01-01-2015 #4
Doesn't need to be complicated just use some foam block which you fasten via bracket or what ever means in front of bearings.
Cut lump out of foam something like the shape of rail just smaller so it conforms to rail shape when forced over rail. The brackets hold it in place.
This just wipes the rail clean of most crap and the bearings own seals deal with the rest.
01-01-2015 #5
I was going to say that double seals and scrapers should take care of any issues, along with greasing at regular intervals. I used an industrial Masterwood for about 10 years where the rails were always covered in dust (sometimes buried), and never had any issues.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
keeping DTIs perpendicular for runouot checks
By dsc in forum Machine DiscussionReplies: 9Last Post: 13-03-2014, 02:41 PM -
round rails
By wilfy in forum Rails, Guideways & BearingsReplies: 51Last Post: 01-11-2012, 01:10 AM -
Why not use unsupported rails?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 39Last Post: 06-04-2012, 03:27 PM
