    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    It looks to me like you connect the tip of the stereo plug to an input pin of the bob and the middle ring of the plug goes to ground. Rather than cut the plug off like they suggested I would get a matching socket, mount it somewhere handy and wire that back to the bob.
    e.g. http://www.ebay.co.uk/itm/3-5mm-Jack...item3cb8d4d762
    dudz's Avatar
    I have already got a socket setup for the probe as it was functioning properly with my previous motion controller board. Now I have swapped this board for the 5 axis BOB, it will not function. It is wired exactly as you just suggested
    Have you tried connecting a mutimeter to it (on ohms range) to see if the circuit makes and breaks when the tip is moved ?
    dudz's Avatar
    It needs between 3V and 24V passing though it to work
    Yes that's to make the LED work but it should still have worked as a probe without the LED coming on
    dudz's Avatar
    yes, as I said it was working right before I changed the bob
    Still no luck
    dudz's Avatar
    No it does not. The probe works though on my Motion control card
  1. FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
    By nobby in forum Items For Sale
    Last Post: 24-09-2014, 09:08 AM
  2. Replies: 3
    Last Post: 18-05-2014, 03:40 AM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. WANTED: Need electronics, anyone upgrading??
    By fasteddy in forum Items Wanted
    Last Post: 25-09-2009, 06:46 AM
