31-12-2014 #1
Hi guys,
I'm going to have a go at 3d milling in the new year, just wondering what is the "best" wood for beginning with - clean cuts and low price is more important than the aesthetic look of the wood. I thought beech might be a good choice but I'm unsure?
I was also wondering- how does end grain take to milling compared with side grain, is the difference notable? I ask because I was considering getting some 'bowl blanks' to try out.
Thanks in advance, and hope you have a happy new year,
Mark
31-12-2014 #2
American Maple, Basswood (lime). You can get good stuff from John Boddy Timber Boroughbridge but go into the big sheds and buy sawn boards if you can rather than from the sanitised 'consumer' bit.
The Following User Says Thank You to EddyCurrent For This Useful Post:
31-12-2014 #3
I have used beech and it does cut nice and finish well.
The drier the better obviously, movement in the wood is the biggest problem, I can fly cut a bit of oak and within hours it's bent like a banana. I made a nice sign for a friend's house, it looked great at first but it quickly curled in on itself, I must have left it too long before oiling it and the moisture must have escaped too fast on one side. :(CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
The Following User Says Thank You to gavztheouch For This Useful Post:
31-12-2014 #4
When buying wood you need to buy the nearest thickness board to your final requirements. Cutting thicker boards into thinner ones generally always results in warping because thick wood has a higher moisture content in the middle. Sometimes if you can cut it, lay it flat, and put a heavy weight on top, it will dry out flat over a period of time, but you'd need some packers under the bottom and under the weight to allow air to circulate all around the wood.
31-12-2014 #5
take equal amounts off both faces
any fine grade wood should be fine, but for just "playing" with I would just use softwood
The Following User Says Thank You to mike os For This Useful Post:
31-12-2014 #6Spelling mistakes are not intentional, I only seem to see them some time after I've posted
31-12-2014 #7
The harder the wood, the cleaner it tends to cut.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
31-12-2014 #8
agree, but the op want to try 3d... so probably going to crash somewhere a few times.... I don't see the point in wasting good wood, using more power and accelerating tool wear to "practice", you can do that when you have got somewhere close to wher you want to be
fruitwoods, yew etc..are probably the best, anything with a tight grain structure will usually machine well and hold fine detail
01-01-2015 #9
All thats been said plus Also good idea to bring the material into enviroment it's going to live and leave for while before cutting so it settles and adjusts to temps/moisture.
The longer and closer to the temp/moisture enviroment it's going to live before machining the more stable it will be.
01-01-2015 #10
Thanks for all the replies, very helpful.
Hardwood CNC from wood on a budget, Possible?
By Hopey in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 16-11-2014, 07:03 PM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
Help understanding the software side of cnc routing.
By don_jarr in forum CAD & CAM SoftwareReplies: 5Last Post: 23-06-2011, 01:13 PM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
