agree, but the op want to try 3d... so probably going to crash somewhere a few times.... I don't see the point in wasting good wood, using more power and accelerating tool wear to "practice", you can do that when you have got somewhere close to wher you want to be
fruitwoods, yew etc..are probably the best, anything with a tight grain structure will usually machine well and hold fine detail
The Following User Says Thank You to mike os For This Useful Post:
01-01-2015 #2
All thats been said plus Also good idea to bring the material into enviroment it's going to live and leave for while before cutting so it settles and adjusts to temps/moisture.
The longer and closer to the temp/moisture enviroment it's going to live before machining the more stable it will be.
01-01-2015 #3
Thanks for all the replies, very helpful.
01-01-2015 #4
Not sure if its available there but Jelutong is a wood that is often used for hand carving because its very fine grained for a relatively soft wood. Its not very expensive, cuts lovely on cnc roters and is easy on cutters. Its pretty bland looking though but maybe you can try it.
01-01-2015 #5
I milled in all sorts of hardwood. Oak is a nice finish, and also walnut. but so far the best finish ive had has been from sapele. Once it got varnished it turned very dark and very glossy, the varnish brought out the natural glossy finish of the wood.
What size pieces are you looking for and where abouts in the country are you. If your close i might have a few bits i can give you.
Hardwood CNC from wood on a budget, Possible?
By Hopey in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 16-11-2014, 07:03 PM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
Help understanding the software side of cnc routing.
By don_jarr in forum CAD & CAM SoftwareReplies: 5Last Post: 23-06-2011, 01:13 PM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
