02-01-2015 #8
No single.
Well that's certainly cheaper than what i looked at thanks.
The driver I am looking at is around 29 pounds, and I have to get a 4 axis Bob as mine is a 3 axis (has to be USB controlled 200khz as I have no printer port = 65 pounds)
To get a double head setup.....buy two extruders and 2x nozzles ??
I guess the bed on ebay is "slightly better" as it comes complete, but then there is an added post charge. Does nobody make larger heated beds ? I'd like one the same size as my cutting bed 500x300
Apart from all the parts above and a custom made Z plate adapter for all of it, is there any other hardware needed (apart from cable/connectors) ?Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
What's needed for a 3d printer build??
By Davek0974 in forum 3D Printing MachinesReplies: 26Last Post: 18-02-2014, 11:54 AM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
RFQ: Looking for member with water cutting ability
By m.marino in forum Projects, Jobs & RequestsReplies: 7Last Post: 06-07-2011, 03:30 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
