    Being belt driven, 3D printers usually move faster. But than again, don't worry yet, it pretty much goes down to what size your printed object has. A very large object will mean longer distances during travel moves, while smaller objects require short distance moves. Also, nowadays slicers can use various toolpath strategies such that using already printed areas from the current layer (when possible) for traveling moves, hence minimizing the ooze - the already printed area from the current layer being at the same height as the nozzle and acting as a plug.
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I have managed to change the motor settings to X = 7000mm/min . Y= 3500mm/min and Z = 1800mm/min
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    Y axis has a different screw lead, or is it because of the weight that it has lower maximum feed?
    dudz's Avatar
    Quote Originally Posted by Trispectiv View Post
    Yes. The Y axis is quite heavy, plus it has the weight of the WC spindle on it.
    I see. So did you mount the extruder?
    dudz's Avatar
    I have made a mount. But those speeds are for when the spindle is mounted. When I mount the extruder, I will take the spindle off the Z plate.
    True, you will be able to reach slightly faster feedrates after taking the spindle off. Well, drop a couple of photos after you have run your first couple of test prints.
  1. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  4. RFQ: Looking for member with water cutting ability
    By m.marino in forum Projects, Jobs & Requests
    Last Post: 06-07-2011, 03:30 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
